C2: 63 Headlight Buckets vs Skins - NCRS Discussion Boards
  • David Hicks
    I have a really basic question, but it has gotten to the point that I am completely confused now. I am in need or a set of 63 Headlight buckets in fibreglass. I currenty have a set of metal ones that someone installed. I know that my VIN is middle year and that the metal weren't installed until the very end of 63. Since one is damaged and I have to paint anyway, I want to install the correct ones.
    Now the confusion: I have seen the fibreglass listed as "skins" in fact Long Island has the following listing:
    53A HEADLIGHT BUCKET FIBERGLASS SKIN (LH)_________________ 63 1 60.00
    53B HEADLIGHT BUCKET FIBERGLASS SKIN (RH)_________________ 63 1 60.00
    I have also looked around and found some people willing to sell used or NOS fibreglass buckets but they are asking ~500 + for the set. The metal ones run at about $265 each and this would be in line with that..... so I need to know if I am missing something. Are "skins" still the same as the metal buckets but in fibreglass or does it mean something else. Why would I be seeing such a difference in price.
    Any help would be appreciated. Thanks
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2: 63 Headlight Buckets vs Skins
    The 63 bucket is made up of several parts, some fiberglass, some metal. The skins are just the outer covering. So if you had a set, but they are damaged, you could change the outer skin to repair.
    • Tom D.
      • September 30, 1981
      • 2134
      Do you mean to say that you could "skin" with fiberglass, starting with the later metal bucket? (I don't think that is what you intended - Thanks). /td
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
      • David Hicks
        I think I understand where you are coming from, but I have my doubts that this is an item you can purchase as just a "skin" (minus brackets etc to mount). As per the diagram at Long Island (similar to the one I have in various books) it seems to be the complete unit. You can see what I mean at:
        http://www.licorvette.com/pdfcatalogfiles/cat21/04.pdf
        I am just trying to confirm that there is no need to purchase a "lining" to these "skins" or that I can just buy the 63 specific parts and rebuild with the parts I have mounted (a 63L - 67 set of buckets in metal).
        • Charles M.
          • March 1, 2002
          • 155
          I have a 64 with rusty buckets, on the bottom when closed. Will I need complete replacements or can I also do some kind of a skin fix if this is my only problem with them?
          • Wayne W.
            • April 30, 1982
            • 3605
            Re: Trust Me
            Trust Me, He aint goint to sell you the buckets for $60. That is just the skin that goes on the rest of the 63 assembly. And Chuck, the 64-76 bucket dont rust. You will have to repair or replace the HL bezel, but the bucket aint rusted.
            • Wayne W.
              • April 30, 1982
              • 3605
              Sorry Tom. I meant that you could buy skins for the 63 bucket assembly, but you cant install them on the metal 64-67 buckets.
