Oil pressure - NCRS Discussion Boards
Oil pressure
  • Ben Raines
    Oil pressure
    I have a 73 vette with a ZZ4 motor (less than 1000 miles). Running at approx. 2800 RPM, my oil pressure reads around 63 psi. Is this to high? At idle, pressure reads around 20 psi. I'm using Mobile 1 synth. oil. Thanks
  • Mike M.
    • May 31, 1974
    • 8389
    Re: Oil pressure
    no problem with the psi figures you noted. have fun with the old girl mike
    • Jim T.
      • March 1, 1993
      • 5351
      Re: Oil pressure
      My ZZ1 crate engine in my 70 at startup with 5W30 Mobil One almost pegs the guage to the right. Pressure after warmup is less, the ZZ1 does hold a higher oil pressure under normal driving conditions than my original 350/300.
