Spark Plugs 427/435 - NCRS Discussion Boards
Spark Plugs 427/435
  • Brian Bates
    Spark Plugs 427/435
    Does anyone have an AC spark plug guide to determine application options for a completely original 1969 427/435 L71?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Spark Plugs 427/435
    for every day street driving use AC R45XLS gapped at.035
    • Dave S.
      • August 31, 1992
      • 2926
      You also could consider a straight 45N AC plug. No extended tip (S) to deal with.
      • Clem Z.
        • January 1, 2006
        • 9427
        extended tip plugs are no problem in BBC even with 12:1 pistons. the extended tip allows you to run a hotter plug to keep clean in town driving but at WOT the fuel wash helps cool the plug tip making it act like a colder plug.
        • Daniel S.
          • February 1, 2000
          • 164
          Brian,
          I have been using AC Rapid Fire #4's on my stock '68 L71.
          5,000 street miles later on first set, no problems at all.
          Dan
            • 43236
            Brian------
            The 1969 GM specs for the L-71 spark plugs were as follows:
            standard operation----AC R-43N
            cold plug for highway driving----- AC R-42N
            The above are not necessarily the best plugs to use, but they are what was recommended by GM in 1969 if that's what you're after.
