I've found a wealth of information on the Board and in the Archives, but can't seem to locate a discussion on disassembling the ventilator assembly (vent window and forward door glass channel) on a C2 roadster.
I've removed the assembly from the door and had no trouble removing the regulator and the vent window itself.
How do I....
1. Remove what appears to be a rivet holding the vertical channel to the angle shaped base metal (chrome) frame? The top of the channel is attached to the frame with the upper window stop screw.
2. Separate the fuzzy channel, the stainless trim, and the rear vent window weatherstrip from the vertical door glass channel?
3. Remove the (angle shaped) front vent window weatherstrip from the base metal frame?
Thanks in advance for your help, I'm sure many of you have figured this out!
How do I....
