C2 differential codes - NCRS Discussion Boards
  • Tony Reilly
    Hi Guys, I recently looked at an Oct '63 build '64 and the code on the diff case was AN 5 31 63. The turns check verified the actual ratio as 3.55 & posi which matches the AN ( it's a small block) but I have that code as being for '66 not '63. Can't be sure if the diff is the original case since a lot had been changed over the years and it even had a big block in it at one time. Any ideas anyone?
    Thanks-Tony
  • Henry J.
    • November 1, 1999
    • 457
    Re: C2 differential codes
    Tony, the book I'm looking at indicates that code "AN" was used on small block 3.55 positraction applications in 1965 thru 1969 inclusive. I suggest another close check of the stamping to clarify the "63".
    • Tony Reilly
      Hi Henry-Thanks for the verification of AN thru '69. I thought maybe that could be the case but I only have codes for the C2's. I'd bet it's a '68, not a '63 even though I was right under it and cleaned it very well.
