71-72 Side Grill Paint - NCRS Discussion Boards
  • Michael M.
    • April 1, 2002
    • 149
    In planning the repaint of my '72, I've run upon a question:
    The judging guide state that the side grills have chrome edges both horizontally and vertically. My question is - How MUCH of the edge is chrome??
    Is it just the top surface, or does the chrome exposure wrap over the edge and down to the casting ledge which is about 1/16 inch below the top most edge???
    ------- Chrome exposure JUST on top edge
    v
  • Dave S.
    • August 31, 1992
    • 2926
    Re: 71-72 Side Grill Paint
    Mike,
    The chrome is exposed on the outer plane as well as the returns into the casting ledge.
    • Michael M.
      • April 1, 2002
      • 149
      Thanks for the response. That would make this a relatively difficult masking -
      HOW DID THE FACTORY PAINT / MASK these things ???
      • Dave S.
        • August 31, 1992
        • 2926
        Mike,
        I would imagine they had an eggerate mask that had slots that dropped over the" squares" and radius. I would be difficult to make a mask to spray 2 side grilles. Some masking tape and patience should work. Good Luck
          • 15606
          Re: 71-72 Side Grill Paint *TL*
          I have seen SERVICE grilles with the black primer on them, and narrow masking tape still in place over the chrome edges. Does that mean that is how it was done on the line in St. Louis? Not absolutely, but it might be a clue.
            • 15606
            70-72 Side Grill Paint addendum *TL*
            I have been told by folks who were there that the side grilles were delivered to St. Louis already painted. For what it is worth.
            • Michael M.
              • April 1, 2002
              • 149
              So I guess the best way to reproduce this result would be:
              1. Using thin masking tape - cover the top surface and the "sides" of the raised surfaces down to the "ledge"
              2. Turn upside down and spray black primer
              3. Turn right side up, spray black primer
              4. Spray color coat
              5. Carefully remove masking ...
              Thoughts ???
              • Dave S.
                • August 31, 1992
                • 2926
                Mike,
                Your suggested approach sounds right to me. o for it.
                • Michael M.
                  • April 1, 2002
                  • 149
                  One LAST Question:
                  As your looking at a grill, the rear facing surface of forward most side of each square (pointing toward the front of car) does NOT have a ledge, so do you:
                  1. paint the whole rear facing surface
                  2. simulate the ledge by paint 1/2 of the rear facing surface
                  or
                  3. do not paint this surface at all ???
                  I'm betting the answer is 2, ie: paint it so that the masking line is uniform around each square.
                  Thanks for all the help!!!
                  • Daniel Grunwald
                    Mike,
                    I recently painted the grilles in my 70 and it wasn't as difficult as it might seem. I used the green masking tape and masked across the top of the chrome edges and then used a small scalpel, (available in model hobby stores), to cut the unstuck part of the tape to the right width. You can also hold the knife at a slight angle if you want to lap a small amount of tape wider than the actual face of the chrome. The green tape holds better and seems to cut sharper than the cheap stuff. They also make some line tape in different very narrow widths that is sold in office supply stores used in drafting applications. Or, as my body shop guy does it, paint the grilles and use a razor blade to cut the paint off the chrome. It takes patience but it works better than you might think.
                    Dan
                    • Dave S.
                      • August 31, 1992
                      • 2926
                      Mike,
                      Upon inspection of my original paint 71 I see that the rear side of each eggcrate is painted body color. the only surfaces that are left chrome are where the "ledges' exist.
                        • 11648
                        Dave,
                        You don't, by chance, have a way to take and post a link to a digital [picture, do you? Either that or I will most definitely have to look at your car this summer.
                        Patrick
                        • Dave S.
                          • August 31, 1992
                          • 2926
                          Patrick,
                          I'm slowly learning the photo/internet thing. I will give it a try. Maybe I can email a couple of photos to you and you can post. I will be at Hershey for sure as the judging confirmations came from Roy yesterday.
                            • 11648
                            Dave,
                            I don't have any confirmation as of yet for judging. I'm holding on getting a hotel room until then. Hopefully soon...
                            Patrick
                            • Juliet P.
                              • June 30, 1999
                              • 349
                              There are detailed photos of several 1970 original grilles showing overspray patterns and paint details on the 70 Registry website. In 1970, only the horizontal chrome and forward most vertical chrome edges were originally exposed. The photos are in the Resource / Photo Library / Exterior section. http://corvetteforum.net/c3/1970regi...xtdetails.html ~Juliet
                              2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
                              1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
                              1965 Coupe (Greg's project No Flight)
                              Gone but not forgotten:
                              1987 Yellow Convertible 199k mi.
                              2002 Yellow Convertible 100k mi.
                              2007 Atomic Orange Coupe 140k mi. RIP flood 2015
                              2007 Lemans Blue 6-Spd Coupe 34k mi.
