63 Power Loss - NCRS Discussion Boards
63 Power Loss
  • Lyle Hayer
    63 Power Loss
    Hi guys,
    Has someone experienced the symtom of power loss and a sort of pulsating surge and release of power from a base 250 hp powerglide unit. The carter Carb probably needs a rebuild but this occured overnight. It doesn't feel electrical, it almost feels like it's starving for fuel. Or maybe some vaccum leak. I was on my way to San Diego, I went through the process of checking the meter rods and linkage and float adjustment is next. Am I close. I wonder if the powerglide could be involved. When parked and I bring the idle up, I don't have any loss or hesitation. I'm fishing for some advice. Thankx in advance.
    Lyle
  • Chris Robertson # 37813
    Re: 63 Power Loss
    Two years ago my 63 250hsp powerglide did about the same thing. It was a windy spring day, didnt think much of it. The next time I took it out it was a really windy day figured it was just the wind, then I heard a ticking noise, then the water temp started climbing, oil pressure dropped, blew the top radiator hose, spun rod bearing, complete rebuild. The fellow who rebuilt the motor gave me no clue as to why it happenned other than stuff gets old. Hope this is not the case with yours. Wish I would have sent one of those engine oil samples in though. And I did want to repaint the engine compartment anyway so it wasnt all bad. Good luck
      • 15674
      Re: 63 Power Loss
      Just a thought: When was the last time the sintered bronze filter in the fuel inlet was replaced?
      • Mike M.
        • May 31, 1974
        • 8385
        Re: 63 Power Loss
        PULL APART THE INGITION HARNESS FROM THE FIREWALL SIDE OF THE FUSE PANEL, THOUROUGHLY CLEAN ALL THE TERMINALS, COAT SUCH TERMINALS WITH SILICONE DIELECTRIC GREASE(DELCO PART), REINSTALL THE ING.HARNESS TO BACK SIDE OF THE FUSE BLOCK, TAKE IT FOR A SPIN(STOMPING HEAVILY ON THE CLUTCH PEDAL S0METIMES WILL PRECIPITATE ENGINE CUT-OFF IF THERE IS A CORROSION PROBLEM AT THIS ELECTRICAL JUNCTION) IF THAT DOESN'T CURE PROBLEM, PROCEED WITH IGNITION & CARB INVESTIGATION.YOUR POST WASN'T TOO CLEAR IN REGARDS TO WHETHER THE CAR IS LOOSING POWER OR SHUTING OFF COMPLETELY ON AN INTERMITTANT BASIS, IF ITS INTERMITTANT, FOLLOW ABOVE ADVICE. IF ITS LOSS OF POWER, PROCEED TO IGNITION/CARB INVESTIGATION. GOOD LUCK MIKE
        • Lyle Hayer
          Re: 63 Power Loss
          Just in , thankx for thoughts. I'll try another filter Duke, although the engine runs and revs up fine in park. It doesn't have any intermitent electrical feeling of loss power, it's more of a starving for fuel, maybe the fuel pump diapham. I'll get back to it tomorrow. Thank you all.
          • Bob R.
            • June 30, 2002
            • 1595
            Re: 63 Power Loss
            One other item you might want to check. The hose from the vacumm advance to the carb. If it slips off or is cracked it can cause the symptoms you described.
            • Jim T.
              • March 1, 1993
              • 5351
              Re: 63 Power Loss
              Probably not your problem, but it was with my 64 convertible once. Remove the distributor cap check that the centrificial advance is not rusted at the pivot points. My 64 had so much rust/dirt on the pivit points that the advance would stick open. It was only 4 years old at the time. That thought me regular maint on the centrifical advance and have used Blue Streak point rubbing block grease after every cleaning to prevent wear, I only use a very, very light application.
              • Lyle Hayer
                Re: 63 Power Loss
                Thankx all, running smooth again.
                Lyle
                • Harry Sadlock
                  Re: 63 Power Loss
                  What was the fix?????
                  • Lyle Hayer
                    Re: 63 Power Loss
                    Memory Loss..... The carb filter I swore I replaced last oil change.
