Speedo Cluster Fit - NCRS Discussion Boards
Speedo Cluster Fit
  • Paul Rose
    Speedo Cluster Fit
    How good or bad does is the cluster housing and speedo fit on a 58 -60? I understand from some phone calls that this fit is less than perfect on many of these clusters and it may have to do, as this may not be as bad as I think. The speedo has a gap on the lower sides to the left and right of the tack. The other gauges fit fine. This is only seen when looking into the cluster from the side. Should I try to find a better housing or is this an up hill battle! Any input is welcome, thanks.
  • Ed Jennings
    Re: Speedo Cluster Fit
    What you are seeing is probably normal. The fit between the speedo bezel and the housing is usually less than perfect. There is little or no adjustment of this fit available.
