58 tach 270 hp vs. 290 hp Question - NCRS Discussion Boards
  • John S.
    • July 31, 1990
    • 292
    I have a 58 tach that has the reading of 8000 RPM and has no rev, counter. I new that this tach was used on the 290 hp fuel car but did not know that it was also used on the 270 hp car. Were both of these tach's internally the same or were they different, since one ran off the gen. and the other on the dist, If they are different is there any way you can tell which one you have? Thank's for any help. john
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: 58 tach 270 hp vs. 290 hp Question
    My 58/60 Manual is up at my shop. My memory says only 290 '58's used the 8K distributor drive tach. But my memory is probably up at the shop too.
      • 43207
      John-----
      The FI distributor driven tach was different than the 270 hp generator driven tach. For 1958-only, the distributor driven tach was GM #1548706. The 1958-only 270 hp generator driven tachometer was GM #1548773. Look for some vestige of one of these 2 numbers on the rear of the tachometer.
      By the way, distributor-driven and generator driven tachs for the same, basic application are usually internally different due to the different rotational speeds relative to engine speed of the distributor and generator.
      • Dennis C.
        • January 1, 1984
        • 2409
        Thanks Joe... I believe on the back of the tach will be a stamping that will indicate what internal gearing the tach is equipped with: eg - calibrated for 1/2 engine speed (dist drive)...
        • John S.
          • July 31, 1990
          • 292
          Re: 58 tach 270 hp vs. 290 hp Thanks Guy's
          Thanks for the help guy's. Much appreciated, john
