1961 Ignition Problem - NCRS Discussion Boards
  • Gene #39090
    Re: 1961 Ignition Problem
    Had the same problem in hot Arizona, starter gets hot and draws too much current. I had the starter rewound with more windings than stock, will now start a 400hp 331ci at 280 degrees.
    • M W.
      • July 31, 2001
      • 835
      Hey Mike,
      I hope you are doing well. It has only been doing this recently. I am planning on looking into this further as soon as I get a free moment of time. How's your car progressing? Please keep in touch.
      Craig
      • M W.
        • July 31, 2001
        • 835
        #18
        Dennis,
        You bet I will definetly follow up with a report. I did contact John Pirkle on possibly doing a starter rebuild. I wonder if my local shop here can do the same job with the same affect? Any ideas here professional vs. local shop?
        Thanks Dennis,
        Craig
        • Ed Jennings
          #19
          Craig, any auto electric shop worth anything ought to be able to rewind your starter in a matter of a few hours and provide a guarantee. I think this typically costs around $75 at least in my part of the world. They will aslo be able to test your started under load, but probably won't be able to duplicate the high heat condition.
          • Mike Nelson
            #20
            Douglas Battery on Broad St does this kind of work. They fixed my generator in just a few hours. I'm doing the final interior work on my car now. Hopefully, I'll pull up in your driveway this spring!
