c2 cluster lens - NCRS Discussion Boards
c2 cluster lens
  • rich heimbrod
    c2 cluster lens
    do they all go convex or concave and does the plastc seal? in the steering column need to go back in. i don't know what it is called and i can't find it in 67 assem manual or ecks.
  • Kieran A.
    • April 30, 1987
    • 87
    Re: c2 cluster lens
    Rich,The concave side of the lens faces the driver/steering wheel.You'll have to be more specific regarding the plastic seal in the steering column.Regards,Kieran #11373
    • Mike Sasser
      Re: c2 cluster lens
      65 judging guide says " Check to ensure lenses are installed correctly with the concave (depression) side in"
      • rich heimbrod
        Re: c2 cluster lens
        thank you kieran and mike could i get another response to varify since both responses are opposite
        • Ed S.
          Infrequent User
          • September 30, 1988
          • 23
          Re: c2 cluster lens
          Rich,
          I believe both replys are attempting to say the same thing. To avoid having to remember concave vs. convex...install the lens such that the distance from the center of the lens to the driver (when sitting in the seat) is at it's maximum.
          Good luck,
          Ed
            Re: c2 cluster lens
            instrument face ( driver
            Only exception is '67 U15 Speed Warning - they have plastic lenses in the tach and speedo (instead of glass), and they're semi-conical conVEX to the driver.
            • Kieran A.
              • April 30, 1987
              • 87
              Re: c2 cluster lens
              John,Are you sure there is an exception to the '67 with speed-minder? I have such a car and prior to having the dash removed and repaired,the plastic lenses were in the same orientation as the non-U15 cars.I believe the Vette Vues fact Book by Dobbins shows it pretty well... When the cluster was returned,the tach needle did rub on the lens; I assumed that the needle length of the replacemnet tach mechanism was shorter on the U15 cars,and that the General only provided one sevice replacement part,so everyone started flipping the lenses around to correct the rub.Any thoughts? Regards,Kieran #11373
                Re: c2 cluster lens
                Kieran -
                Noland's book describes the convex plastic lenses, as does the '67 TM&JG; the link below is a photo of the cluster in Dobbins' personal '67 U15 car, and the reflections show the convex lens shapes pretty clearly.
                Dobbins' '67 U15 Speedwarning Cluster
                • Kieran A.
                  • April 30, 1987
                  • 87
                  Re: c2 cluster lens
                  John,Thanks for the information and the photo. I guess the cluster needs to come out again to reverse the lenses. Oh well,its all up hill after you drop the a/c ducts! Thanks again,Kieran #11373
