I bought a 493 waterpump a few weeks ago and found some strange things when I took it apart today. The waterpump was a flint 493 casting and when I took it apart I found all the mating surfaces to be like new with original factory machining marks intact and no corroison on the neck or the internals of the pump. This matched up with the story of this pump sitting in a cabinet for over 30 years. When I started bead blasting it, as I cut through the grease, I found that the pump was painted a pale yellow color and I found no evidence of any other color as I cleaned the pump to it's bare cast state. Did any GM division paint any of their engines this color or was the small block used in any marine applications tht anybody knows of that used this light yellow color? all of the internals were original parts, so it is unlikely that this pump was used on anything other than a brand-new engine, but the color is a real puzzle!
Regards, John McGraw
