1973 Corvette Yellow Dealer Promo. Model - NCRS Discussion Boards
  • Tim Keeler
    If you have a yellow '73 promo model and are thinking of selling it, drop me a line. I'm not a collector, but do own a '73, so I don't need the box, etc. Just as long as it's in good shape. Thanks, TK P.S. Looking for spring tags - 1973, L-82,no a/c: Should read MA. And the engine code sticker: CLR . If you have any leads, I'd appreciate your help.
    • 43222
    Re: 1973 Corvette Yellow Dealer Promo. Model
    Tim-----
    The labels are easy. You can get them from many vendors. M.F. Dobbins has specialized in these various labels for many years. You can visit his web site at www.yankeelady.com/dobbins/index.htm or call at 215-443-0779. Also, these labels are available from Paragon. These labels are fairly inexpensive unless you're looking for a reproduction late 69+ blue, driver door certification label. In that case, they're NOT so inexpensive.
    As far as the '73 promo goes, usually these are not too difficult to find unless you're after a specific color(they usually aren't even available in all colors for a specific year model). Check out the eBay auction at www.ebay.com. They're usually there to be found. If you intend to be at any of the big Corvette shows like Bloomington or Carlisle, there will be plenty available.
      • 43222
      Tim-----
      • Tim Keeler
        Hey Joe,
        Thanks for responding so quickly. I'll check w/ Dobbins. Most reproduction people ie: Paragon etc. has them for a '73 454 w/a/c only, nothing for small blocks w/o air. It's the same way with the engine code sticker. I've looked for these for quite a while. Thanks again, TK
        • Tim Keeler
          Hey Joe,
            • 43222
            Tim----
            Paragon's catalog only lists the labels you mention, but it says that they have others available. In any event, I feel you're doing the right thing by contacting "Dobby" Dobbins. He will either have what you need available or will be able to tell you who does if he doesn't or will be able to tell you that what you seek is not currently available. Either way, you should be able to put the matter to rest once and for all.
              • 43222
              Tim----
              • Tim Keeler
                Hi Joe: I sent Dobbins a message last night but no reply. It occurs to me I e-mailed him w/ the same request quite awhile ago but never received a reply. The two pieces I needed didn't appear on his web-site. I checked with every repro outfit I've come across in the last five years with no success. And many of the tags offered are not correct for a '73. I want the correct ones so I'll just keep checking, the car is probably one of a handful that had the no A/C L-82 combination. I'll probably post another message with what I need. Thanks for your help. Keep in touch.
                • Tim Keeler
