65 Power Brake Booster setup - NCRS Discussion Boards
  • William C.
    • May 31, 1975
    • 6037
    Does anyone have an easy, accurate way of setting the position of the yoke that threads onto the shaft on the back side of the brake booster/ Either a measurement from the rear of the mounting bracket to the rear of the yoke or a dimension from the rear of the mounting bracket to the centerline of the clevis pin hole would be perfect. All I can find is "use some J-xyz tool" and I need a "home mechanic" approach. All help appreciated.
    Bill Clupper #618
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 65 Power Brake Booster setup
    Bill, I would think that the measurement would be somewhat variable between diffferent cars. I adjust on the car.
      Bill -
      Adjust the clevis on the car after installing the booster to get 1/16"-1/4" pedal free play before you feel resistance from the power valve in the booster.
