1967 L36 oil pressure - NCRS Discussion Boards
    Infrequent User
    • August 31, 1994
    • 25
    My oil pressure goes from zero at startup to pegged right while running. I stuck a 100 psi gauge on and its reading 70 psi. Motor has just been rebuilt. Could this be a potential problem or is this normal?
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: 1967 L36 oil pressure
    My guess, your engine rebuilder installed a high flow/high pressure pump that might have use in racing applications. A rebuiler told me once he uses these as most customers view high oil pressure reading as a sign of a superior rebuild. I prefer the factory pump & pressure. Why waste horsepower pumping oil.
      • May 31, 1974
      • 8389
      agree twith the dipstick. rebuilder probably installed the l-88 style pump. shouln't hurt anything unless you intend to performance verify the car, in which case keith biggers will frown on the higher than normal idling oil pressure. by the way no one knows how to cheat a few extra hp out of his engines than dennis
      • Vinnie P.
        Editor NCRS Restorer Magazine
        • May 31, 1990
        • 1567
        This is Scary *TL*
        That both these guys, Mike McCagh, member #14, and Dennis (Dipstick) Clark have finally learned how to use a computer. Between them, they probably forgot more than all of us combined will ever know about Corvettes.
          • 15601
          Re: This is even scarier *TL*
          That they both agree on something. (Forget the cheating accusation. That is jsut trash talk.)
            • May 31, 1974
            • 8389
            we both agree on something because we both now sleep at the foot of the same cross
            • Dennis C.
              • January 1, 1984
              • 2409
              I can't even get a "TL" designation. But, what do I care, I'll settle for a reaction time that's about a half minute better than Mike "MD Missle" McCagh.
              • Clem Z.
                • January 1, 2006
                • 9427
                just tell them you have 50W oil in the engine that is why the pressure is high. by the way what weight oil are you using?
                • Dennis C.
                  • January 1, 1984
                  • 2409
                  Yo Clem... If I didn't own/ride a Harley, I wouldn't even know what you were talking about. Sounds like STP stuff to me...
                  • Loren L.
                    • April 30, 1976
                    • 4104
                    When you live in the rain forest, you
                    don't worry about extra heat in the motor - you try for it, so the hot dogs cook faster.
