1961 Choke Housing - NCRS Discussion Boards
1961 Choke Housing
  • Art B.
    • 333
    1961 Choke Housing
    Can anyone suggest a source for a choke housing, part #170583, used on a 3059S
    WCFB Carter carb? One of the three "ears" that accepts the screws to hold the assembly together is broken. I also need the piston. I hope I don't have to buy a complete rebuilt WCFB to get what I need. I checked all the catalog houses but none are listed for a 1961.
    • 43221
    Re: 1961 Choke Housing
    Art-----
    The choke housing assembly that you need is GM #3759936. The piston is GM #1172253. Of course, both are long-since GM discontinued. Parts like these are probably best obtained by stripping them from an otherwise junk carburetor. The problem is that there were an awful lot of different choke housings and pistons used on these carbs over the years, so you have to find a carb of the same part number as yours to be sure you'll get the right parts.
    You can obtain an NOS example of the housing by calling my old buddy "Mr. 64 Impala" Jody Anderson at 612-727-2404.
    • Art B.
      • 333
      Joe:
      Thanks for the info. I will try a local junk yard. The man says he has a lot of old Carter four-barrel carbs. If I strike out there I will call your buddy. I notice that he has a Minnesota area code so he is in my state.
