Can one tell 1.94 vs 2.02 '462' heads from outside - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7024
    Does anyone know how to tell the difference between 3890462 heads with 1.94" and 2.02" intake valves by looking at the casting numbers or for that matter by looking at anything on the outside or on the valve spring side of the heads? If not, how did GM keep track of them in inventory? Some paint broadcast marking?
    Gary
    • 15602
    Re: Can one tell 1.94 vs 2.02 '462' heads from out *TL*
    Both Flint and Tonawanda used paint markings on the end of the heads 20 years ago.
    • Gary B.
      • February 1, 1997
      • 7024
      Terry,
      And these paint markings were eventually covered up by the chevy orange, I presume.
      Gary
      • Joe C.
        • August 31, 1999
        • 4598
        Gary:
        As far as I know, there is no way to tell. They both used the same "double hump" casting, but the 2.02" heads went through a machining process which enlarged the valve seats, and unshrouded the exhaust (but not the intake) valve.
        Joe
          • 15602
          Yes, Gary *NM* *TL*
            Joe -
            The unshrouding machining was adjacent to the intake valve, not the exhaust valve (used a 1.34" dia. cutter head piloted in the valve guide).
            • Joe C.
              • August 31, 1999
              • 4598
              John:
              I stand corrected--I knew it was one of those. Seriously, you jogged my memory, which isn't too good at times. I unshrouded the exhausts, among other things, when I tricked up my heads.
              Joe
