Correct paint - NCRS Discussion Boards
Correct paint
  • Jim38243
    Correct paint
    I need to know if the black GM restoration paint would be the correst paint to use for a midyear engine compartment cleanup/detail. Is it ok for the alternator bracket, sparkplug wire brackets, radiator fan and pulley and air cleaner/vent tube? I understand that the voltage regulator would require a gloss black and that the GM restoration black appears to be a semi-gloss black which is what the guide calls for. Thank YOU!
  • Don H.
    • December 1, 1981
    • 1487
    Re: Correct paint
    Krylon semi-flat black is considered very close. Don H.
    • Jim38243
      Re: Correct paint
      Are you saying know one uses the GM Restoration black paint?
      • Don H.
        • December 1, 1981
        • 1487
        Re: Correct paint
        I am not an expert but I know people with top flight restorations that used the Krylon. I am not familiar with the GM paint. Don H.
