66 coupe vibration - NCRS Discussion Boards
66 coupe vibration
  • Joe Clarino
    66 coupe vibration
    I have a 66 coupe apun excelleration has a vibration in the front to middle of the car. I have replaced the tires and had it aligned with no results. It feels as if it is a broken trans mount( It's Fine) or an unbalanced driveshaft. Has anyone experienced this or have any ideas what it could be?
    Thank you
    Joe
  • Wayne K.
    • December 1, 1999
    • 1030
    Re: 66 coupe vibration
    Joe,
    Have you checked the motor mounts ?
    • Wayne C.
      • November 1, 1978
      • 289
      Also, check the front differential mount cushion.
      • John M.
        • January 1, 1998
        • 813
        Also, check the play in the transmission rear yoke/bushing. I've had this problem with the same symptoms. Good luck.
        • Joe Clarino
          Yes I have. No Problem.
          • Jeffrey S.
            • May 31, 1988
            • 1882
            Joe
            I had a similar problem on my 69 many rears ago except that the vibration only occured over 3500 RPM. The culprit turned out to be a bad fan clutch. At that time I replaced the original fan clutch (which I saved and had restored a couple of years ago)and fan with new GM units. The problem was solved. Many years later I had the original rebuilt and restored and re-installed the original fan and everything works beautifully.
            Hope this helps.
            Jeff Salz
