C2: Exhaust pipe PN#'s - NCRS Discussion Boards
  • Dan Pepper
    Just removed a set of rear-section under car exhaust pipes and found part numbers stamped on them: 3963497 & 8.
    Just wondering if these are service replacement pipes that require clamped-on mufflers or perhaps original pipes that may have been "de-mufflered". Thanks!
  • Robert C.
    • December 1, 1993
    • 1153
    Re: C2: Exhaust pipe PN#'s
    Dan, as far as I know (on C3s) only the header pipes were stamped with the part number. The tail pipes were part of an assembly (pipes and muffler) with a part number paper tag on the front of the muffler.
      • 15695
      You sure about the second digit? My P&A catalog shows 3863497/8 as the rear replacement sections for 64-67 w/ 2.5" pipes.
      The rear section of the base exhaust system was serviced with separate rear pipes and mufflers that were designed to be clamped in the field. Only the off-road system was serviced with the rear pipe section welded to the muffler.
      Different part numbers are shown for '63 probably because of the required jogs to clear the under-seat depressions, but these pipes will probably work on a late '63 without the under-seat floor pan depressions, and for this reason the off-road system will not fit on a '63 with the floor pan depressions.
      • Dan Pepper
        Of course, you're right Duke. Second digit is an "8." Pecking the key board with uncoordinated fingers led to the typo. As always, thanks for the information.
