C2 Water Pump? - NCRS Discussion Boards
C2 Water Pump?
  • Richard H.
    • March 1, 1985
    • 241
    C2 Water Pump?
    Have a water pump #31284 G 2 0*63, but I don't have literature on C2's. Can someone tell me if this was used on Corvettes? Thanks.
  • Jay B.
    • May 31, 2000
    • 8
    Re: C2 Water Pump?
    richard:
    I checked my 1964 judging guide and found that water pumps where not dated untill november 1965...all engines use casting # 3782608 except high proformance uses # 3859326...hope this helps
    my64vet@yahoo.com
    • Craig S.
      • June 30, 1997
      • 2471
      Re: C2 Water Pump?
      Richard - 284 water pumps are big block pumps....check your date to see if the 63 is really a 68, it would then make sense....Craig
      • Richard H.
        • March 1, 1985
        • 241
        Re: C2 Water Pump?
        The date code on it reads: O 63. Could this be some type of aftermarket unit and not a GM Original?
        • Craig S.
          • June 30, 1997
          • 2471
          Re: C2 Water Pump?
          Maybe....is the part number ending in 284 ONLY the digits you indicate? GM uses 7 digits, I don't remember the exact part off the top of my head but it does end in 284. If the pump only lists what you state, then it doesn't sound like a GM pump, but I don't know if there were aftermarket castings in that era yet, maybe someone else knows...Craig
          • Richard H.
            • March 1, 1985
            • 241
            Re: C2 Water Pump?
            This has 5 digit casting number. Then it has a G, not GM. Then the numbers
            0 63 that appears to be a date code. Could it be 1970 June 3?
              Re: C2 Water Pump?
              Sounds like an aftermarket rebuilder casting to me; GM didn't have any 5-digit casting numbers, nor did they have casting date codes for the month past "L", and it would have "GM" on it, not just "G".
