'66 Odometer Problem - NCRS Discussion Boards
  • Chip Levick
    The odometer and trip odometer on my '66 do not work - but the speedometer works fine. I have replaced the speedometer cable and the trip cable and they still do not work.
  • William C.
    • May 31, 1975
    • 6037
    Re: '66 Odometer Problem
    Problem is internal to the speedo head, there is a gear that drives the odo that strips, generally requires new busings and other parts. The Instrument restoration guys can generally fix it as part of their service, or you can check the nearest medium to large city for an old-fashoned Speedometer shop.
    Bill Clupper #618
    • Scott Marzahl
      Dr. Rebuild has the little gears you need if you decide to tackle it yourself.
