63 Rocker Panel Instalation. Help! - NCRS Discussion Boards
  • Gary Kemp
    Any suggestions on installing rockers panels. I left the screws a little loose and so far have not been able to hook the rockers over the mounting strip. Anybody have any suggestions?
  • Chuck G.
    • May 31, 1982
    • 2030
    Re: 63 Rocker Panel Instalation. Help!
    I've had luck keeping the screws loose, then tightening them with an ignition wrench after the rocker is on. Also, put masking tape on the body "bulges" or you'll gouge the paint. Hope this helps. Chuck
    • Wayne W.
      • April 30, 1982
      • 3605
      Hook it over first. Then install screws.
      • Gary Kemp
        Thanx for the ideas. I will be trying it again soon.
        • Gary Cederman
          Gary,
          No judgement here but more of an FYI; You can install the mounting strip upside down and then the rocker will definitely not go on (Eventhough, it looks like it should). You should not have to leave the screws on the mounting strip loose to make this work.
          Yes, it is a tight fit but, as long as the top lip of the rocker panel is straight, it should go on.
          Good luck,
          Gary
