C1 FAN TO WATERPUMP BOLTS - NCRS Discussion Boards
  • Joe D.
    • April 30, 2002
    • 382
    Does anyone know what the headmarks should be for the bolts that connect the fan to the waterpump on a early (100451) 1961, 283,245hp? WB,S, or TR?Thanks, Joe DeLuca #37862
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: C1 FAN TO WATERPUMP BOLTS
    Joe . . .
    3 bolts with "TR" and one stud for the Generator brace.
    • John M.
      • January 1, 1999
      • 1553
      Joe,
      On my 60 which has no fan clutch and has the aluminum spacer, The bolts are TR head marked, but are also grade 8 marked as well. I dont know if anyone produces the correct long bolts with the correct grade marking. The Paragon # 4957 has about the correct head appearance, but the bolt is the shorter bolt that is used without the aluminum spacer.
      Regards, John McGraw
