C2 decklid striker plate rivets - NCRS Discussion Boards
  • Chris Robertson # 37813
    The striker plates for my deck lid need replacing. Ordered a set and was wondering how to set the rivets. They look solid, is there a special tool for this, and where do you get one? Checked at a couple body shops and a hardware store, with no luck. Any help would be great thanks
  • Donald O.
    • May 31, 1990
    • 1591
    Re: C2 decklid striker plate rivets
    Chris,
    I use a pair of small steel plates, one on either side of the rivets and dished on the back side to hole & locate the rivets post. A pair of vise grips and a bowl of cheerios will do it. And the outsides rivet head looks like the original. I like this as it is safer than using a hammer and a buck.
    Don
      Thanks for the info, Knew somebody would have a trick
      • Pete Whelan
        Chris,
        Donald's advice is right on. When setting the first rivet, go slowly so that you get a feel for how much force is needed to deform it. The rivets were easier to deform than I had anticipated.
        Pete
