68-73 Wiper Arm Washer Tubes - NCRS Discussion Boards
  • Harmon C.
    • August 31, 1994
    • 3228
    I have noticed that the metal washer tubes seem to not have any paint on them when the arms still look good on some of unknown originalty. Were the tubes painted and it fell off or were the tubes unpainted?
    Lyle
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 68-73 Wiper Arm Washer Tubes
    Just looked at my original owner 70 washer tubes. Mine appear unpainted and have a grey/charcoal metal color. Did discover during this examination that the vacuum relay that is depressed when the wiper is at rest on the the passenger side has lost the top part of the accordian style rubber piece and I discovered that the spring inside is rusty. Another part to buy.
    • Lee McGlamery
      Hi Lyle - The brass tubing, according to the 1970-1972 Technical Info and Judging Manual, is painted flat black just like the wiper arms. The info in on page 32.
      Lee
      • Harmon C.
        • August 31, 1994
        • 3228
        Jim This is what I thought might be the case as the ones I have the tubes are dark also.
        Lyle
        • Harmon C.
          • August 31, 1994
          • 3228
          Lee It is easier to restore all black and match the book but I will keep looking into this as it may have changed in different years.
          Lyle
            • 43221
            Jim-----
            You're in luck; the part you need is still available from GM. It's GM #5638487 and it's about $45 GM list.
            • bruce11495
              Joe..........Is that the same # for both sides? They have different configurations don't they? Do they fit from 68-72?
              Thx Bruce
              • Jim T.
                • March 1, 1993
                • 5351
                Joe Lucia
                Thanks for the part verification still in GM's inventory and the part number. The parts GM has for our cars after all these years amazes me.
                • Harmon C.
                  • August 31, 1994
                  • 3228
                  Bruce The part number joe gave was not for an arm but a door part found needing replacement when checking original arms.
                  Lyle
                    • 43221
                    Lyle and Bruce-----
                    Yes, the part number which I provided is for the inter-locking valve/switch which Jim described as being deteriorated on his car. Only 1 is used per car. The wiper arms are unique to each side of the car and are both long-since GM-discontinued.
                    • bruce11495
                      Re: 68-73 Wiper Arm Washer Tubes...Thx *NM*
                        • 15601
                        • Juliet P.
                          • June 30, 1999
                          • 349
                          Thanks for the heads up Terry. I do have some photos comparing what I believe is an original valve and the GM Service replacement. I just put them back up on my website. The GM replacement I purchased appx. 2 years ago, so the configuration may not still be the same. ~Juliet
                          2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
                          1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
                          1965 Coupe (Greg's project No Flight)
                          Gone but not forgotten:
                          1987 Yellow Convertible 199k mi.
                          2002 Yellow Convertible 100k mi.
                          2007 Atomic Orange Coupe 140k mi. RIP flood 2015
                          2007 Lemans Blue 6-Spd Coupe 34k mi.
                          • Harmon C.
                            • August 31, 1994
                            • 3228
                            What do you feel on the washer tubes painted or unpainted, fell off , dark colored not painted ?
                            Lyle
                              • 15601
                              Re: Terry *TL*
                              Now that you put me on the spot..... When we did the 1970-72 TIM&JG a few years ago our best guess was a coating of some kind (note I deliberately did not use the word paint). Those tubes do look like there is some kind of coating on them, but we did not have the luxury of seeing a brand new set.
                              Given that everything else on the whole wiper assembly was low-gloss black, including the spine of the wiper blade, and on some arms when the plastic retainers were moved there was an un-coated area under them, we concluded the arm and tube all had the same finish.
                              It certainly would be nice to see the original prints, just to be sure.
