Alternator - NCRS Discussion Boards
Alternator
  • Jim38243
    Alternator
    Where is the best place to get a numbers correct alternator? I have seen them in the Corvette Central catalog but they are supplied to them by someone else.
    Unfortunatley mine (which is on a C2 1965)is not original and I would like to replace it with a correct in every way one. Thanks for your input in advance!
  • Daniel S.
    • February 1, 2000
    • 164
    Re: Alternator
    John Pirkle
    706-860-9047
    • Rob A.
      • December 1, 1991
      • 2126
      Re: Alternator
      Depending on the degree of restoration you are looking for, you may just look for the front half that contains the part# and date you need and switch it with the one on yours. (There are adds in hemmings under corvette "parts and accessories" that offer just that, for around $25 for just the front half). It is easy to do and inexpensive.
      • Jack Layton
        Re: Alternator
        or e-bay Which part number do you need? 1100693 date?
        • Jim38243
          Re: Alternator
          1100693 is the one I need
