C3 Eavap/heater box black goop sealant - NCRS Discussion Boards
  • John A.
    • August 31, 2002
    • 172
    I recently reconditioned the evap enclosure on my 69... There was a black goop waxy sealant used to seal the upper box area where it bolts to the firewall... looks like it was in a liquid state when applied because it ran down the sides then dried... What is (was) this sealant and is there a substitute available today?
    John
  • Frank/Paula Lowery
    Re: C3 Eavap/heater box black goop sealant
    John,
    I rebuilt my evaporator box on our 69 several years ago. At that time Dr. Rebuild carried the sealant you are looking for. It was a rope type sealant that had the consistancy of soft putty. Hope this helps. Thanks.
    • John A.
      • August 31, 2002
      • 172
      Frank,
      Thanks for the responce... but the ribbon sealant used between the "box" and the "firewall" is only part of the story... there is another black goop that was applied just along the top seam... after the box was fastened in place... It is similar (may be the same) to the goop used to seal the in the WSW area...
      By the way, dark gray ribon sealant can still be purchased at the dealer... The stuff I got from Doc was actually brown... still worked though...!
      Thanks again!
      • Zachary K.
        • March 1, 1986
        • 162
        Before you go to the dealer to buy that ribbon sealer at a hefty price. Go to your local Home Depot or Lowes. 3M makes the ribbon sealant and it can be found at either place in Black or Grey. As for the poured looking sealant that was used I have an idea but haven't tried it yet just to see how close it looks to the original sealant. If I try it and find that it looks correct I will post here on how to duplicate it.
        1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
        1969 L71 LeMans Blue, Bright Blue Convertible
        1970 L46 Monza Red, Light Saddle Convertible - Duntov
        1976 L82 Classic White, Firethorn
        2013 LS7 Black, Ebony, Convertible
        Moved on -
        2006 LS2 Black, Ebony, Convertible
        • John A.
          • August 31, 2002
          • 172
          Zach,
          Thanks for the the tip. The box is in place... just tring to figuer out what will work for the goop!
          Thanks...
          • Kieran A.
            • April 30, 1987
            • 87
            John, I found a product at Home Depot called Knight Hawk All Season Rubberized Roof Repair made by U.S. Hickson Products LTD. It was in the roofing section and comes in an 18.5 oz spray can. The can accepts a thin tube(like the one on a can of carberator cleaner) and can be "dribbled" on to the top of the box with great accuracy.When it dries,it stays rubbery and turns a black color. I think it was about $2.00 for the can,but I remember the caps were very dusty,indicating this stuff has been on the shelf for a while and was not new stock. Hope this helps,Kieran #11373
            • Kieran A.
              • April 30, 1987
              • 87
              John, If Home Depot doesn't carry it any more:
              U.S.E. Hickson Products LTD
              15 Wallsend Drive
              Scarborough,Ontario M1E 3X6
              www.usehickson.com product code 371-18U
              Regards,Kieran #11373
              • John A.
                • August 31, 2002
                • 172
                Thanks... I was looking at some of the roofing products... such as the various sealants in a tube... I havent experimented with any of them yet... I guess I have something to look for by name now!
                Thanks again..
                • Harmon C.
                  • August 31, 1994
                  • 3228
                  The dust on the cap is used to age the product for a more orginal look.
                  Lyle
