Numbers Matching '63 ...... - NCRS Discussion Boards
  • Bruce
    I have a '63 vette that is numbers matching.....however, it is a wreck. The frame was horribly corroded and it took about a year to repair it. (Take a look: http://www.geocities.com/split_63) And while the repair is as true to the original frame as possible, a Keene eye can tell it was rusted badly at one time. The body is also in bad shape. It has some very ugly flares on all four fenders. My plan is to repair it with new body panels.
    But when I'm done it will not be the pristine original vette. It will be a '63 that had a rusted frame and has all new body panels.....maybe a whole new front clip.
    As a result I have not been very interested in keeping this vette numbers matching. Its just does not have the right foundation.
    So I have been thinking of selling the engine, which is an original 11:1 340HP motor with 66K miles. Its worth a lot to the right person, that is someone interested in a correct motor., but it is not really of value to me. I personally would rather put an all alloy crate engine in it.
    So my question to the group is what do you think I should do? Keep the original motor in it, even though I plan to use the vette as a daily driver, and will most likely wear through it. Or should I sell it to a good home where it has the potential to create a numbers matching vette, one with a good foundation?
    What do you think such a motor is worth?
    Bruce
    Restoration page
  • Art A.
    • June 30, 1984
    • 834
    Re: Numbers Matching '63 ......
    The only car that engine will match is your car----keep it.
    Art
    • David H.
      • June 30, 2001
      • 1531
      Keep the engine with its car.
      To sell this engine you have to compete with a wide variety of performance crate motors. Anyone just interested in a higher HP, non numbers matching, engine would compare the cost of a new high performance motor to your sale price PLUS the cost of a rebuild.
      If you don't think it's cost effective to rebuild the engine, others will probably view it the same way. Better to store the old motor than sell it.
        • 15676
        Keep the original engine. Sounds like you are doing a lot more than the typical restoration and you will be rewarded more in terms of self-actualization and monetary value if you keep it original. Restoring a deteriorated/modified car to original condition is a lot harder than restoring it with more mods, but is worth the effort.
        The sixties vintage SHP engines are in a class of their own. If you want to refresh it, pocket port/port match the heads/manifolds and use the LT-1 cam and original edge orifice type lifters. This will give you about 275 HP at the rear wheels, and you'll retain that "hot mechanical lifter cam" idle quality that can't be matched by a modern engine, even one that makes more power.
        • Peter Ansted
          Keep the engine, have it rebuilt by a qualified machinist to original specs. This car is a restorers dream. The frame was not rotted completely through, the fiberglass can be repared rather easily, your sitting on a SHP engine and you have already completed the scariest part - removal of the body.
          • Bruce Melvin
            The frame was rotted clear through. And those flares are going to be hell to fix, expecially in the front where each flare cuts into three body panels.
            The engine does not need to be rebuilt. I check one of the rod bearings and the wear was remarkably little.
            Someone who needs a correct motor for '63 could use this motor as is....although given the age of the gasket, I would swap them out.
            • Bruce Melvin
              I would not be selling it to compete against crate motors. This would be the correct engine for any '63 as the numbers, as I understand them, only indicate that it is correct for the year, not for the car. I would only sell this to someone that had a '63 and their goal was number correctness.
              Bruce
              • Wayne C.
                • November 1, 1978
                • 289
                You apparently don't understand the engine numbers... there is a VIN derivative (last 5 digits of your vehicle's VIN) stamped into the pad on the block (just forward of the passenger-side head), which makes the engine correct (matching numbers) for your car alone, not for any other 63 Corvette. It would be period-correct for another 63 built in the same general time period (within a month or two after the block's casting date) that your car was built, but it would not be numbers matching.
                If a buyer intended to restamp the pad to counterfeit the "matching numbers", he can choose from a variety of Chevy block castings from that time period, not just Corvette blocks, which lessens the market value of your block.
                • Bruce Melvin
                  Ok, help me out then. The number on the block is: 5121269 FO6
                  What do you translate this to mean?
                  Bruce
                    Bruce -
                    The 5121269 says it's out of a very late production 1965. The "F06" is a partial number - this code should read F06XXYY, where the X's are a 2-digit number for the day of the month (06=June), and the Y's are a 2-letter code for the engine type. It is not the original engine; '63 and '65 both used the 3782870 block - what is your block casting date (behind the pass. side cylinder head on the rear flange)?
                    • Bruce Melvin
                      John,
                      THe numbers are ?121259 (which matches the serial number on the plate in the car, and F0625RE, which matches the the 340HP claim of the previous owner.
                      Based on this, I now see, thanks to Harry, that this engine is only correct for this car. So I will keep it and love it.
                      Bruce
                      • Art A.
                        • June 30, 1984
                        • 834
                        Bruce, Where you are showing the ? mark on your latest post in the
                        number ?121259-----I think it should be an " S " and if you would have given it the first time we would have been able to help you sooner. Also, when you gave the F06, if you would have given us the complete number (F0625RE)it would have been very helpful.
                        Live and learn
                        Art
                        • Bruce Melvin
                          I think your right, the question mark was/is and "S". Hard to make out the difference between and "S" or a "5". I was going off an picture I took of this area in '98. In the picture it only show the F06. THis morning, after four years, I actually went out in the garage and waded through the mess. I copied the numbers of the block and posted them. Sorry about that.
                          Bruce
                            On a '63, the first digit of the VIN derivative on the engine would be a "3", not an "S" - should show "3121259".
                            • Art A.
                              • June 30, 1984
                              • 834
                              Your right John it should be a 3, I was thinking of the transmission-----the "S" will only show up on the tranny---Sorry,I'll go back to sleep now.
                              Art
