C1- Capacitors - NCRS Discussion Boards
C1- Capacitors
  • Dennis A.
    • April 30, 1999
    • 1010
    C1- Capacitors
    Can the capacitors mounted on the Generator, Regular, and Coil be all the same? I note that the GM P/N's are different and Originals are hard to locate.
  • M W.
    • July 31, 2001
    • 835
    Contact Jack Humphreys
    You can find his e-mail on here somewhere. He always seems to have a few concourse correct ones in his trusty stash.
    Craig Willetts
    • Dave S.
      • August 31, 1992
      • 2925
      Re: C1- Capacitors
      I Jack can't help, John Pirkle most likely can.
      • Roy Braatz
        Re: C1- Capacitors
        They are all different because of the wire coming out plus the part number. Any early year CHEVY. is the same as Corvette year to year for C1's mostly .
        • Mike E.
          • February 28, 1975
          • 5138
          Re: C1- Capacitors
          You can check the AIM under the radio section and they list the part nos--which are also stamped on the end of the cans. We also have those listed in the judging manual.
          • Christopher R.
            • March 31, 1975
            • 1599
            Re: C1- Capacitors
            They go for around $30 each all the time on EBay. I got one that came with a generator attached for $10 there.
