1961 Soft top attaching bolt type - NCRS Discussion Boards
  • M W.
    • July 31, 2001
    • 835
    Could someone please tell me what bolt head was used to attach the soft top frame to the vehicle? I have looked all through the 1961-62 TI&JG and can not seem to locate any reference to this. A picture would also be nice if available. Also could someone send me a picture of where the soft top straps are located? Thanks so much.
    Craig Willetts
    NCRS# 36551
    1961 2x4 245hp
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: 1961 Soft top attaching bolt type
    Craig . . .
    Rather than describe the Soft Top Frame to Bracket Bolts, You can order them from Corvette Central P/N 54118,(est. $6.00) also the Bracket to Bulkhead bolts are available.
    • Roy Braatz
      They are carriage bolts all that I have seen.
      • John M.
        • January 1, 1999
        • 1553
        Craig,
        Roy is correct in that all bolts are of the carriage bolt style and are available from you local Home Depot. I do not believe that the originals had any head marking. The exception would be the bolt that attaches the upper-outer bracket to the body on each side, and I think that a TR head mark is the correct bolt. In any event, this is the configuration that I used on my 60 and it did not draw any comments from the judges.
        Regards, John Mcgraw
        • Mike E.
          • February 28, 1975
          • 5138
          The originals that I've scavenged over the years from 61s and 62s are carriage head bolts that have a little "twist" to the head so that it isn't a perfect domed shape. All have had an R B W marking on them, except for a few with no head marking at all.
