posi-traction oil - NCRS Discussion Boards
posi-traction oil
  • Wayne Roache'
    posi-traction oil
    Can anyone identify the following; p/n 1050081, is a quart can of GM posi oil. The front of the can has, Special Formula, Multi-purpose rear axle, gear lubricant. The back of the can has, Limited Slip and conventional type. Does this oil contain all the necessary additives, meaning that the current additive p/n 1052358 is NOT required?
  • Art A.
    • June 30, 1984
    • 834
    Re: posi-traction oil
    Wayne, If you are unsure of it's contents, just package it up and send it to me----I'll use it "as is"-----It's the real deal! I have a quart that I have been guarding with my life for 20+ years. The "other" quart that I had is in my 65 and is functioning as it should.
    Art
