67' caliper rebuild - NCRS Discussion Boards
67' caliper rebuild
  • mike Arteaga
    67' caliper rebuild
    I'm rebuilding the rear suspension and the calipers are leaking. Any suggestions on who to send them out to? I put about 300 miles a year on the car!! Thanks Mike Arteaga #34566
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 67' caliper rebuild
    Mike - vette brakes did a great job on mine, I got their O-ring seals and pistons. Make sure you tell them it is for an NCRS restoration and they well mark their ID numbers on the inside faces of the calipers so they are not visible, and will not grind the caliper external housings for stamping like they typically do. They will also paint them correct black versus silver. They do excellent work on the calipers from my experience...Craig
    • mike Arteaga
      Thanks Craig!!
