HELP!!! Can anyone tell me the name of a paint stripper I can safely use on the fiberglas on my 57 corvette. It has Lacquer paint on it and I need to take it down to the fiberglas to repaint it with base coat/clear coat. Please respond.
paint stripper
Re: paint stripper
Blue Lightning Restoration Products 800 501 1562 Spray on pain remover, works excellent, won't hurt gelcoat. Just keep spraying it over itself, paint comes off easily, however, lacquer will not come off as easy as other types.- Top
Re: paint stripper
Regardless of which stripper you decide to use, make sure that you wash the body thoroughly. It seems that you can not wash the fiberglass enough to remove all traces of stripper. When you think you have washed it enough, wash it again. You do not want any surprises later.- Top
Re: Stripping Fiberglass
John . . . I used Auto Spra-Strip and the Eckler Fiberglass repair products with excellent results. After working for months on doing the job right, My recommendation is to have good blasted do the job. The time saved and the end result quality, Blasting is will worth your thinking.- Top
Urban myths and disasters
This advice is based my personal experience.
If you attempt to strip the paint off a Corvette body with a razor blade, you will nick it up. Especially in the corners and recesses.
Blasting (sand, bead, plastic, walnut shell, you-name-it) will destroy the factory surface texture of fiberglass body panels.
Most chemical strippers are safe for fiberglass, but some urethane strippers are so powerful that IF YOU LEAVE THEM ON TOO LONG, they will cause the resin to swell.
The chemical strippers I have used have never reacted with the new body paint. I rinse the body once with tap water after stripping.
Painting over old paint will cause surface imperfections to appear in the new paint over time.
I have never encountered a Corvette with a factory "gel-coat" on the outer skin.
Grinding or sanding off the factory primer will destroy the factory surface texture of fiberglass body panels. This primer can be safely scrubbed off, however, with steel wool or Scotchbrite type pads soaked in stripper.
I have never found a chemical stripper which can melt Imron or Featherfill.- Top
Re: Urban myths and disasters
I agree with Jerry on most points except that I have had stripper get into the glass and come back to haunt, so I will not let the stripper go any farther than the original primer and then sand that off. I have not done Soda blasting but I have heard good things also. On the subject of sand or bead blasting, My feelings are that it is fine, and I have had very good results. But you have to know what you are doing, and I wouldnt take the chance on letting someone else do it for me. I blast just enough to peck the paint up and then easily sand off the remainder of the paint. This leaves a nice surface and does not damage the fiberglass.- Top
Re: paint stripper
I used CMA Fiberglass Stripper 520F (CMA Chemicals, Phila, PA) with good results on my '62. Took about 3 gallons since I had to go through lots of clear & lots of metalflake paint. I scrubbed with Scotch-Brite pads & lacquer thinner to remove primer. As has been mentioned!! - rinse good with soap & water many times & let sit in sun to dry out!!
Bill- Top
