C2 Big Block Water Pump - NCRS Discussion Boards
  • John R.
    • September 30, 1999
    • 288
    On my way home this afternoon I heard a loud rattle from the front of my 67 big block. Upon investigation, it sounded like a marble in the water pump. The sound continues for about five seconds after the engine is shut off and sounds very much like the steel ball on a roulette wheel. Is it the water pump impeller or a piece of it? The engine was running a little warm but not unusually so for our 80 degree Phoenix weather. I'd really appreciate some advice before I tear down the front of the engine.
  • george romano
    Re: C2 Big Block Water Pump
    Also check the fan clutch, as well as the fan belts. It could also be an alternator bearing.
    George
      Is the engine "running-on" or "dieseling" after you shut the key off, or does the noise continue for five seconds after the engine has actually stopped rotating?
      • John R.
        • 288
        The sound continues after the engine stops rotating. It sounds like a good size ball bearing rotating in a circular enclosure. It is not the water pump, alternator or power steering as I have pulled all the belts in anticipation of of pulling the water pump. I thought that it might be the lower pulleys contacting the frame but they are stopped while the sound continues. I am relly stumped on this one. The engine is running great.
        • george romano
          Is it an auto or 4 speed?
          • John R.
            • 288
            It's a four speed. Sound seems to be in the front of the engine.
            • John R.
              • 288
              With a fresh start this morning, the mystery has been solved. The problem is the balancer. It looks like I will have to remove the radiator and jack up the engine to fix it.
                Is the balancer original, or is it one of those aftermarket "TCI Rattlers"? The "Rattler" is indeed full of steel shot/ball bearings, and at low rpm some of them sound like the inside of an outhouse in a hailstorm
                • John R.
                  • 288
                  The harmonic balancer was freewheeling like a hula hoop. I can't tell what was holding the outer ring to the center hub. It looks like it was a rubber sleeve but there is no sign of it anywhere. Guess I was lucky it didn't damage the timing chain cover.
                    John -
                    You're very lucky - usually they come apart and tear up everything forward of the timing cover, including the radiator, shroud, and the hood
                    • John R.
                      • 288
                      And I thought the Corvette Gods were frowning on me! I had just rebuilt the carburetor, had John Pirkle rebuild the broken nose in the starter and installed a new battery when this happened. I don't know what I would have done if what you described had happened. Thanks for the post, John.
