C3 court lamp location - NCRS Discussion Boards
  • Ed Driscoll
    Hi Guys,
    I have a lamp that I identify as the left hand court lamp. It's been hanging in space since I bought the car. I can't seem to locate it's housing or mounting area. Does anyone have any insight on this little buggers home. I see a small pressed bracket under the dash to the left of the column, but the hole is too small. Other then that, I can't find any other place for it.
    Thanx
    Ed #38868
  • Bernard S.
    • June 30, 1992
    • 56
    Re: C3 court lamp location
    You are correct that bracket is the mounting point for the court. lamp. Try removing the bulb from the socket, attach the socket to the bracket, and then insert the bulb. Also check the bulb for correctness.
