C2 Oil Pan Restoration - NCRS Discussion Boards
  • Scott Landis
    Can anyone recommend someone on the West Coast to fix (rod through the side) and restore a C2 327/350hp oil pan?
    Re: C2 Oil Pan Restoration
    Most local machine shops will do the job for you. The 'trick' will be sitting & talking to the machinest to negotiate 'how pretty' you want the resulting exterior surface to appear after repairs (grind and hide weld marks vs. simply straighten & 'plug' the hole)....
