I have a 66 L79 which has the incorrect brass repro radiator. I've had this car since september. I notice now that I'm using the heater that the coolant temp goes down from an indicated 200 to 180 when I put the heat on. Does this indicate that the radiator is not being the best of heat exchangers? I have heard both; that the brass is ok, and read another post reporting 20 degree cooler results all around after changing to aluminum. BTW, I have been through all the temp sender stuff and I know the car is not running too hot and I believe the radiator is clean, altough I did not do it myself. Just curious about the effect the heater has on the coolant temp. and whether there is a concensus that the aluminum does a better job of exchanging heat.
Rich Giannotti
Rich Giannotti
