C-1 Needle bearings on steering box - NCRS Discussion Boards
  • Don Ursery
    Can anyone help me on removing both needle bearings & seal on '62 steering box. I've seen tools in ST-12 (don't have any). Just hoping someone has done this recently. Can I remove Pitman side bearings & seal with press and socket? The adjustment side (side cover bearings) are my main problem. Thanks for any help.
  • John M.
    • January 1, 1999
    • 1553
    Re: C-1 Needle bearings on steering box
    Don,
    You are correct, you can just dismantle the box and either press or drive the bearings out with a punch.
    Regards, John McGraw
    • Roy Braatz
      Remove pitman arm useing a puller and then removing side cover bolts and pull unit out. Then you can also remove steering wheel and large hex nut at the box , then lower the steering shaft enough to use a punch through the side cover to drive out the rear sector seal , then bearing.
