'64 Power Brake System - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2660
    I am planning to install an original power brake system on my '64 Corvette. I have located an original power brake master cylinder with the correct bleeder scwew. Am I correct in that the power brake master cylinder requires a different (longer) actuator rod that attaches to the brake pedal than one found on a non-power brake master cylinder?
    Also, are there any other components other than the power brake booster and intake vacuum fitting w/hose in a '64 power brake system that are diffeent than the non-power brake system? Items such as wheels cylinders, brake shoe return spring kits, brake lines both metal and flexible?
    Best Regards,
    James West
    Omaha, NE.
    NCRS #18379
    1964 Corvette Convertible #9258
  • Dino L.
    • February 1, 1996
    • 694
    foot pedal rubber *NM*
    Dino Lanno
    • Dennis M.
      • April 30, 1988
      • 160
      Re: '64 Power Brake System
      James,
      One other thing to be aware of, there is a riveted nut plate on the firewall to support the power brake booster. This may an easy fix or not, depending on lining it up with the booster.
      Dennis
      • James W.
        • December 1, 1990
        • 2660
        Dennis,
        Thanks for the info. I'll look into that.
        James West
