67 Master Cylinder Piston assy - NCRS Discussion Boards
  • Craig S.
    • June 30, 1997
    • 2471
    I am getting ready to assemble my 67 509 1" master cylinder after brass sleeving from Apple Hydraulics. I now have a Bendix rebuild kit, and it came with a new rear piston assembly with seals, and all seals for the front piston plus a new hardened thin washer for behind one of the front piston seals. All parts appear very high quality and US made, it was of course, a special order part. Upon cleanup of my old Delco front piston assembly, it is serviceable, and will work, but it does have a fair amount of pitting in the casting at various points. Does anyone know if the Rabestos kit contains BOTH front and rear pistons? I suspect not, the price was similar with both in the $35 range. I believe NAPA's kit did not either when I had someone check..it was around $41. I would really rather have a new front piston as well before assembly, if possible...thx!...Craig
    • 43260
    Re: 67 Master Cylinder Piston assy
    Craig------
    I don't know of any master cylinder rebuild kits that contain the secondary (rear) piston. Even the GM kits, when they were available, did not contain this piston. It was always a seperate part. The GM secondary pistons have been discontinued for many years.
    As far as I know, none of the aftermarket brake parts suppliers offer the secondary piston. But, it's worth checking into further. They must be manufactured since new master cylinders are available which include the piston. Also, I would guess that master cylinder commercial rebuilders must be able to get them for those instances in which the piston must be replaced rather than just re-sealed.
    In any event, a new secondary piston is available for the price of a new master cylinder.
    • William O.
      • April 30, 2001
      • 355
      Long Island CSI has a rebuild kit that says with front and rear pistons:
      Section 52 item 19 D2
      Bill
      • Craig S.
        • June 30, 1997
        • 2471
        Thank you Joe and Bill! I should have checked with LI Corvette first...they frequently have hard to get items....thx!...Craig
