C2 Wiper Washer Hoses - NCRS Discussion Boards
  • Ralph E.
    • February 1, 2002
    • 905
    Just today I was changing my original dried out wiper washer hoses with new replacement hoses from LCI and made a discovery. The hoses from LCI are correctly ribbed but they are slightly larger OD. Anybody else ever make the same observations.
  • Brian M.
    • February 1, 1997
    • 1841
    Re: C2 Wiper Washer Hoses
    You might want to check with DR. Rebuild.
    • Craig S.
      • June 30, 1997
      • 2471
      This is a common problem.....Dr Rebuild is the way to go...his are the correct OD as well...Craig
      • Steve Shanks
        I just discovered the same problem.Since I will not be showing my car I kept the slightly oversize hoses.A tip for you ...put the hose through the grill grommet before you install the grommet> you might have some vasoline handy also.
        • Ralph E.
          • February 1, 2002
          • 905
          I did the samething, installed the slightly larger hoses. If I ever go for a major show I'll make a change then.
