Vent Window Regulator - NCRS Discussion Boards
  • Bob Sandoval
    Anyone aware of a kit to repair a vent window regulator for a '65 roadster. The protruding turning shaft (for lack of a better description)is stripped and new regulators sell in the $200 range. Close door and window crank falls off. Any suggestions appreciated.
  • Wayne K.
    • December 1, 1999
    • 1030
    Re: Vent Window Regulator
    Bob,
    Are you sure your not just missing or haven't correctly installed the retaining clip ?
    • Bob Sandoval
      Thanks for response.
      I actually tightened retaining clip by crimping it with pliers. The turning shaft is stripped and the indenture where the clip seats is pretty smoothed out and rounded. I cannot turn the crank because the gear teeth on the shaft are almost gone.
      • Gene M.
        • April 1, 1985
        • 4232
        Bob, Since the splined shaft with the worm gear is generaly not the part that wears out. Get a used assembly and swap out the parts. It takes some drilling and thread tap to make the repair. Coups and conv. are different so get the correct assembly.
          Try Dennis Hardesty at (618) 344-0021; he rebuilds them.
          • Lyle Hayer
            Hi Bob, I recently replaced dr. side vent reg. on my 63 Coup. Mike at AmericasFinestsvette manufactures a terrific replacement. If you want I'll dig up his number. Lifetime warrenty. Little over a hundred bucks.
            LDH
            • Bob Sandoval
              I would appreciate his number or email. Thanks for your response.
              • Bob Sandoval
                John, Thanks for response.
                • Lyle Hayer
                  Hi Bob,
                  Michael Mermelstein
                  corvetteusa1@sbcglobal.net
                  1-888 318-3883
                  • Bob Sandoval
                    Lyle, thanks for taking the time.
