intake manifold - NCRS Discussion Boards
intake manifold
  • Dan Tewell
    intake manifold
    Still looking for a 70- 72 LT1 intake manifold. I've found one that the person says is a "service replacement". It has a number of 3972116.Is he trying to pull a fast one? The numbers I have are 3972110 or 3959594. Thanks
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: intake manifold
    110 is a 1970 370 HP, 594 is a 1971 330 HP and 1972 225 HP. 116 is a service replacment,over the counter manifold.
    • Dan Tewell
      Re: intake manifold
      Thanks Clem. Since it is a service replacement, would it be identical to the original manifolds except for the casting and date code numbers? I guess what I'm getting at is, are they all visually and functionally the same, if not what would be the differences?
      • Jack Layton
        Re: intake manifold
        Try the following: Go to Google and type in "3972110 for sale". Hit enter.
        OR Try e-bay. Try different filters like the part number, or Z-28 intake manifold, or corvette intake manifold . Look at e-bay # 2400164124 or 2400118903. The last one seems to have all the correct numbers except the last digit. Is it a "6" or a "0". The part # advertised is 3972116 ?? BTW which year are you trying to find? The above data was focused on the 1970.
        • Clem Z.
          • January 1, 2006
          • 9427
          Re: intake manifold
          as far as performance and fit it would be the same just the date and part # would be different.
          • Ralph E.
            • February 1, 2002
            • 905
            Re: intake manifold
            Dan, Check your email
