I started doing some fibreglass work using cloth and resin to repair damaged areas on my '57 transmission cover. All went o.k. and after sanding it was quite smooth but you can see all the repaired areas, they appear darker than the original fibreglass. Since this area is not painted, is there any way to color the resin to blend in better with the unpainted areas? This would also apply to the under-floor areas. Thanks.
Brian
Brian
