rear main seal - NCRS Discussion Boards
rear main seal
+ More Options
Posts
  • Jack O.
    • July 31, 1996
    • 527
    rear main seal
    Hi everyone,
    First, thanks for all the help on the oil pan. I evened it out with a ball-peen hammer which worked great.
    Now that I have the pan off I can get a good look at the rear main seal area. It doesn't appear to be leaking. I'm basing that on the fact that the small counterweight on the crankshaft between the seal area and the bellhousing doesn't appear to have any oil on it. The engine (69' 427) was rebuilt about 7 years and 5000 miles ago but the car has sat for 5 years. I've put about 1000 miles on it since then and it was leaking a lot of oil around the pan. I assumed the seal was leaking also. What should I be looking for to determine if the rear seal is leaking? Should I replace seal anyway since the car sat so long? I guess I'm a little hesitant since you have to remove the bearing cap but from reading the instructions it seems like it is a straightforward job.
    Thanks in advance,
    Jack Ottofaro
    Jack Ottofaro
    • 43247
    Re: rear main seal
    Jack-----
    As long as you have the pan off, replace the rear main seal at this time. It's very easy to do and removing the rear main cap is no problem, at all. Use seal GM #10117767. Follow the procedure EXACTLY as described in your Chevrolet Factory Service Manual and don't neglect to use sealant in the areas shown in the diagram in the manual. Reintsall the main cap and torque the bolts to specifications. That's all there is to it.
    • Clem Z.
      • January 1, 2006
      • 9427
      Re: rear main seal
      see my post on the CRPL board as i point out the problems with aligning the rear cap on a BBC
      • Kevin T.
        • August 31, 2002
        • 84
        Re: rear main seal
        Clem, where exactly is that post you are referring to? I would be interested in reading it also. Thanks. - Kevin
        • Clem Z.
          • January 1, 2006
          • 9427
          Re: rear main seal
          go to http://archives.gigo.com/crpl/2003-01/maillist.php look under 11:12
