TI coil wiring - NCRS Discussion Boards
TI coil wiring
  • Pete Lovrovich
    TI coil wiring
    I am finding conflicting information as far as which wire connects to the positive and negative poles on my coil. I have a 66 with an L72 and have reached that point of firing it off after a very long time living in my shop. I am not sure if the white wire connects to the pos. or neg. pole. Also if I connect the wrong one (of which I may have) will this hurt my amplifier unit. I do not seem to be getting any spark to my plugs. I would be very grateful for any help or advise you may give.
    Thank you.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: TI coil wiring
    white resistor wire to the - and the black wire to the +. make sure you do not have any paint on the amp where the black ground attaches.
    • Clem Z.
      • January 1, 2006
      • 9427
      Re: TI coil wiring
      i can scan you a wiring diagram and flowchart for trouble shooting the TI if you want it.
      • Pete Lovrovich
        Re: TI coil wiring
        Thanks gents, for the response. I would like some trouble shooting information if you have it.
        Thanks again, Pete
        • Clem Z.
          • January 1, 2006
          • 9427
          Re: TI coil wiring
          i will need your e mail addy because it no longer shows up on this site.
          • Pete Lovrovich
            Re: TI coil wiring
            My e-mail add. is plovrovich@noanet.net. Thanks again.
            • Donald S.
              • August 31, 1996
              • 186
              Re: TI coil wiring
              Pete,
              Check out T.I. Specialty's web site. Dave Fiedler has a wealth of information to help you with any problems. http://www.tispecialty.com/info.htm
              Don Smith #28087
