C1 King Pin Uprgade - NCRS Discussion Boards
C1 King Pin Uprgade
  • Pat F.
    Infrequent User
    • April 1, 2000
    • 6
    C1 King Pin Uprgade
    Stainless Steel Brakes Corp. makes an upgrade King Pin Kit for 1953-1962 Corvettes called "Royal King Pin Kit". This kit eliminates the brass bushings and instead uses needle bearings. Has anyone installed this kit or know if it is worth while considering? Thank's Pat.
  • Dave Suesz
    Amazing- just yesterday...
    I noticed that listing in the SSB catalog, and planned to ask this very question! I can say I have dealt with SSB at the wholesale level, and I have always found their products and service to be quite good. I am anxious to hear from someone who has used this product, as my original 122,000 mile kingpins could use a little help.
    • Ed Jennings
      Re: C1 King Pin Uprgade
      I have trouble imagining that one could tell a difference in steering effort. I'm sure the needle bearings would last longer, but how many years is it going to take to wear out as set of OE style kingpins on a weekend driver? 40?, 50?
      • Tom Parsons
        Some of us put a lot of miles on these old frontends. Plus, they could also be used in 49-54 pass car frontends. My very first car, a 51 Chev which I bought from my Granddad in 62, is my daily driver, 40 mi/day. I would be particularly interested in knowing if just the bearings are available seperately.
        • Verle R.
          • March 1, 1989
          • 1163
          The needle bearings require a different kingpin. The KP diameter is smaller than used with bushings.
          I too am interested in any experienced comments.
          Verle
          • Tom Parsons
            Well, if the kingpin is a smaller diameter, then how is the pin locked in place in the upright with the lock bolt?
            • John M.
              • January 1, 1999
              • 1553
              The pin is only smaller where the roller bearings bear, near each end of the pin.
              Regards, John McGraw
              • Tom Parsons
                So are you saying the kingpin has the original diameter in the center and a smaller diameter on each end?
                • John M.
                  • January 1, 1999
                  • 1553
                  That is correct, just go to their web site and you will see some pictures of them.
