67 column bearing - NCRS Discussion Boards
67 column bearing
  • Roy Braatz
    67 column bearing
    My 67 steering wheel has up and down play and I know I need a column bearing , but was told there are two kinds. How can I know which one I need??
  • James W.
    • December 1, 1990
    • 2660
    Re: 67 column bearing
    If you have up and down play, you may have a "tang/clip" broken off of the sterring column tube. I thouht I needed the upper bearing replaced but it ended up being the tang on the column tube.
    James West
    Omaha, NE.
      Roy -
      The same upper bearing was used on all 67's; two different lower bearings were used - one for "early" cars through February, and one for "late" cars after February - LICS has both types.
      • Roy Braatz
        John thanks , I thought it was the upper bearing have two different ones. The upper I think I need? Where should I order one?
        Jame thanks, Where is the tang located , at the bearing seat? should I remove the steering wheel to check?.
        I'm into 55 Corvettes mostly, but my 67 coup 327-350hp-4sp and is dead stock , second owner, goes like a raped Ape, why she is so fast geting up to 110 MPH I never could understand.But I love it so.
          Roy -
          Long Island Corvette Supply, 800-466-6367. The upper bearing is item #18-21c.
          • Scott Marzahl
            I thought my '67 upper bearing was also worn out and ordered a new one from LI too. When I dis-assembled everything I discovered that the area where the upper bearing is installed was warn and the bearing was slipping around. I used some JB weld to tighten things up and I no longer have any steering wheel movement.
            A search of the archives turned up similar experiences of worn bearing seats.
            • Roy Braatz
              I just got the bearing from Corvette Stop for $35.00 and they told me that there are three tangs that hold the bearing in and tight. To remove the bearing I had to brake the tangs install the new bearing and cement it in, As scott said
