Correct belts on 71 w/AC - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    I would like to put back original style and type of fan belts on my 71.
    Engine is a 350 270hp with power steering and A/C
    Are the belts cut or wrapped.
    What are the GM numbers and length of each.
    Does anyone know if they are available from GM or after market.
    Ralph
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
  • Donald L.
    • September 30, 1998
    • 461
    Re: Correct belts on 71 w/AC
    Ralph,
    Quanta Restoration Products are the GM Restoration licensed Co for belts.They
    can tell you the length as well construction.Phone # (410) 658 5700.
    Donald #31176
    • Ralph A.
      • May 31, 2002
      • 236
      Thanks, placed order today *NM*
      Ralph Adams
      NCRS: 38137 LA: 112
      Slidell, LA 70461
        Caution....
        the reproduction belts are faithful (cloth wrapped) but for them to fit/work, you really need to verify you have all of the factory original pulleys on the engine (most are stamped with P/N and should correspond to what's listed in your AIM book).
        Next, if you intend to drive the car vs. show it primarily, I'd think twice about these reproduction belts. I broke two in less than a year on my '71 SB Air roadster and went back to current day, GM service replacement technology (die cut belts). I get partial credit on the judging field as they ARE GM sevice replacement belts and I've logged +50K miles on the car since doing Founders award four times without incident....
        • Ralph A.
          • May 31, 2002
          • 236
          Re: Caution....thanks, will carry tools
          Car is planned to show or drive to special events. I will get a set of cut belts for the trips.
          Ralph Adams
          NCRS: 38137 LA: 112
          Slidell, LA 70461
            • 11638
            Re: Caution....
            Agreed.
            Jack and I both have 1971 350270 w/AC's, and we've both had the same problem with the belts. I've got Goodyear Gatorback belts on mine now as I'm driving it now.
            Patrick
